phase shift a signal data
hi all
          i want to phase shift a signal of 90 degree. i am having the signal data  as 1d array,using the data i want to shift the phase of the the signal .....any one....
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
Message 1 of 9
(12,344 Views)
There is an option called "Rotate aray".Do u mean that?
Message 2 of 9
(12,342 Views)
Do you want to time shift or phase shift?  The Hilbert Transform  in the Signal Processing>>Transforms palette is used to phase shift signals 90 degrees.
Randall Pursley
Message 3 of 9
(12,341 Views)
Hi Indar,
You have several options--however the best is to devise a formula for the phase shift and then put this is the formula node in LabView to process the array data. Alternatively, you can use the Hilbert Transformation to apply a uniform phase shift to waveform data. Please refer to Echo Detector.vi or my simple example attached below.
Ipshita C.
Message 4 of 9
(12,311 Views)
And how i can do phase shift with 120 degree?
Message 5 of 9
(8,721 Views)
What is the nature of the signal?  For a sinusoid, a phase shift shifts the entire waveform in time by an amount -(phase shift in radians/(2 pi f), so a 1Hz sinusoid shifted 90° = pi/2 would be shifted in time -(pi/2)/(2 pi) = -0.25 seconds.  The usual convention is a phase lead (positive numbers) means the waveform is advanced, so the "delay" is negative.
If your signal has a variety of frequencies in it, did you want to phase shift all of them by the same phase?  Note that since the phase shift will shift-in-time depending on the frequency, the components of your composite signal will be shifted differing amounts, potentially changing the nature of the signal.
Bob Schor
Message 6 of 9
(8,715 Views)
  How can I make Signal ( one dimensional array of ) in to phase shift of 90 degree?
Message 7 of 9
(8,173 Views)
Sigh.  You really need to take a Signal Theory class, then you'll understand your question is meaningless, particularly without knowing the nature of the signal (which is what I asked earlier).  So here's a method guaranteed to work for any signal:
  • Plot the signal on a piece of paper.
  • Rotate the paper a quarter turn to the left.
  • Voilà, a phase shift of 90º.
Bob Schor
Message 8 of 9
(8,154 Views)
Bob 😄
Task solved ... see my sig 😉
And they never tell us why they need to do it. Signal theory classes help, however in my experience you need to deal/play with real tasks for some time to get a understanding*.  For the class/test it's more often a simple (but still complex) application of math rules.
How comes that I have areal and  imaginary  signal part in my real copper wire...
Why (and why not!)  my signal representation is equivalent  in time and/or frequency domain...
Effects of discrete time ...
Greetings from Germany
Henrik
LV since v3.1
Message 9 of 9
(8,138 Views)
