phase shifting
How could I get two signal with different phase angle from same signal simulator ?
@rahul
(4,208 Views)
What is a signal simulator?
(4,198 Views)
I'm referring to simulate signal function used as block diagram window in labVIEW.
@rahul
(4,158 Views)
You can e.g. use the Sine Waveform.vi under Signal Processíng -> Waveform Generation. It allows to enter a phase.
Cheers
Edgar
(4,149 Views)
The Simulate Signal Express VI also has a phase input (it uses Sine Waveform VI internally).
Rahulro if you need two signals with different phases then you just put two Simulate Signal express VIs and wire different phase values to them.
Cheers,
J.
(4,141 Views)
Jarek, I did the same but I was just thinking of using only one Simulate Signal express VIs.
@rahul
(4,127 Views)
