phidgets relay connection
Hi! I have connect phidget to LabVIEW. I am trying to activate the relays using LabVIEW so that I cna hear the clicking sound to make sure that the relays are activated. However I am not sure how to conncet to the relay. Attached is my attemp to make the LabVIEW to activate the relays. It is not working. I think the out port. vi might not be the right object to activate the relays. I will really appreciate your suggestions and help.
Samia.
(3,517 Views)
Do you have the relay board connected directly to a parallel port???? Aren't those Phidget things USB? I think you are off base.
Message Edited by Broken Arrow on 06-16-2010 01:07 PM
Richard
(3,506 Views)
Just look it up. Neat devices! Anyway, since they use Automation (as shown in your VI), there will be a proprietary property node to set the relays. Did you look at the LabVIEW samples on their website? How did you get the idea to use the PORT VI's anyway?
edit: and did you install their drivers? (COM).
Message Edited by Broken Arrow on 06-16-2010 01:21 PM
Richard
(3,496 Views)
