physical channels missing in project
One of my coworkers is running into an odd behavior that he feels has changed overnight.
When he creates a new vi in the project environment (it can be a brand new project/vi) and puts down a "DAQMx Physical Channel" control on the vi's front panel it doesn't show the actual channels on his development system (i.e a list of Dev2/ai0, Dev2/ai1,... on my machine).
Yet, if he creates a vi, with a project being opened (new project or existing) the control operates ok. It is driving him batty, he is one that gets very upset when LabVIEW behaves in a manner that isn't consistent, and has come to me. I, in turn, come to the power of crowd sourcing an answer!
LabVIEW 2012 sp1
As always, Thanks in advance.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,551 Views)
Hi Putnam,
I get the expected behavior on my machine (drop down the DAQmx Physical Channel control from the palettes and see the available channels on my machine). If he right-clicks on the control and goes to "I/O Name Filtering..." and plays around there, does that fix the problem? At the least, he should have "External Channels" checked. I apologize if this seems over-simple, but it's worth a shot.
As he is able to do this in the block diagram using a VI, I am assuming that the device shows up in MAX and he can properly communicate with it when he runs the VI that allows him to select the desired terminals?
Rahul B.
(2,456 Views)
