pico 5000 series oscilloscope
Have tried the example files provided by Pico for labview and they work fine.
I want to scale the amplitude and timebase,.
Called the DLL's that were in the Pico SDK so I could call them in my program.
Version of Labview I am using is 2014 so saved the following files into the Labview, 2014,  'resources' folder from Pico SDK as detailed in their posts on this site:-
Ps5000a.dll
Ps5000aWrap.dll
Picolpp.dll
Fine so far....
Then created a 'call library function'  from Dll for ps5000aMinimumValue  using C:\Program Files\Pico Technology\SDK\lib\ps5000a.dll in my program followed by further icon from ps5000aMaximumValue from same location i.e. C:\Program Files\Pico Technology\SDK\lib\ps5000a.dll.
Program then runs but I get no values for Min value or Max values only trace.
Really frustrating because feel I am missing something obvious....
Thanks Jack
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
(3,877 Views)
Post your code! It's very difficult to see if you 'missed something obvious' unless we can see what you've done. Preferably post a .zip containing the minimum amount of code that demonstrates what you are doing and the problem you are having.
(blog)
(3,821 Views)
Thanks for reply and usually would have provided a code snapshot but using DLL's and links thought a bit much.
 Problem was found to be using the DLL incorrectly and not stating a value in it first follwed by a pointer to that value.
Labview Version 8.5
Labview Version 8.6
(3,758 Views)
can you pls share the code....
(2,700 Views)
