picoscope 5012
Greetings gentleman :
I have the following problem.
I have a Picoscope 4226, a device that can function as signal generator and oscilloscope, very good machine.
The problem i have is that when i try to use it as signal generator controlled by labview, i receive an strange error.
Let me show it to you.
Error 5012, i researched about it but couldn fix it. Does anyone has any experience with it ?.
Kind Regards,
Stgo.
(4,057 Views)
Looks like your handle became invalid.
Post some code, or a link to the code you are using.
(4,052 Views)
Ok, this is the code.
The code is actually the same that came with the example in the driver.
Kind regards,
Stgo.
(4,041 Views)
This is an intermediat VI function.  You cannot just run this and expect it to work, it needs to have an open function run before it, and then the output of the open will be a Handle.  You then need to provide that handle to this function.  I assume an example would ship that has all these needed functions (open, configure, close) all in one VI.
(4,039 Views)
