picture control mouse property
In LV 8.5 I notice that if you reinitialize your picture control to default value (using pop-up menu) the mouse position property no longer works, it will always return 0,0 no matter where the mouse is in the control.  You must destroy and re-create your picture control to fix it at that point.
Maybe this has been fixed in later versions of LV but I have not seen any documentation of this.
(4,774 Views)
Good Afternoon Garvacious,
When you say the pop-up menu, I assume you mean the menu that appears if you right-click on the control.
I just tried this in LabVIEW 8.6.1.  My mouse cursor position reads 0,0 when the mouse is over the control and -1,-1 when the mouse is not over the control.  This is a bug.  I have filed the appropriate internal documentation (Corrective Action Request #167102) so that R&D is aware of the issue.
Thank you for letting us know about this behavior.  I am sorry for any inconveniencce this bug has caused you.
(4,731 Views)
I'm using LV 2009 on Windows XP and it still hasn't been fixed; i get -2147483648, -2147483648 both inside and outside the control. Was it fixed with 2010?
(4,389 Views)
Hello Snamprogetti,
As of today (LV 2010 SP1), a fix has not yet been implemented.
(4,381 Views)
It is also still broken in LabView 2014 SP1. The only fix is to delete the 2D Picture object and make a new one (copy and paste the control/indicator does not fix it)
(3,836 Views)
Accepted by rolfk
In LV2020, you get -2147483648, -2147483648. So not fixed.
There is a fix!
Setting the zoom factor with the Zoom Factor property resets the behavior. The value doesn't need to change, so this works:
Haven't tested this in older versions, but works wonders in LV2020.
(3,327 Views)
Fixes the problem in LV13 as well.
Just to make sure, this does not fix the bug! It is a workaround to recover from the bug. It's easier than replacing the control and reapplying all properties and cosmetic changes.
(3,323 Views)
