picture fade out
Zguljo
Member
picture fade out
Hi all!
I would like to make picture at start of application to fade out (same size as front panel) in order to get menu which was previously in the back ground of the same picture. Can someone please give me an idea for that?
Vedran
27 REPLIES 27
Norbert_B
Proven Zealot
Re: picture fade out
Vedran,
there are many options, but all condense down to: transparency.
I think the easiest method is to use a seperate VI (splash screen) and use the Front Panel Window:Run VI Transparently Property to fade the whole VI frontpanel out.
This might get a bit tricky for positioning under different resolutions of the systems the application should run on, but still quite easy to solve.
hope this helps,
Norbert
PS: Please note that when faded out, the splash screen VI has to be quit.
Norbert
Expert: Geometry
Wiebe@CARYA
Active Participant
If you want a splash screen to fade away, and have the real main VI appear,
it is a lot easier.
Make a VI with the picture. Make it floating, or modal. Also, set the
transparancy (in VI Properties>window appearance) to 0%, but make sure the
value is tagged. You can make the splash screen the same size as the caller
(main) vi with property nodes.
Now, in a while loop, simply put 0 to 100 in the Panel>Transparency property
of the VI. Put a 10 ms wait in it, and the front panel of the VI will
dissapear in about 1 second.
If you want to do it with a picture control in the same VI, it is a bit more
difficult.
First you need to get a picture of the VI with a VI method. Get it's 2D
array of pixels with "Unflatten Image". Do the same with the splash picture.
Now, in a dubble for loop for each pixel, alpha blend the to pixels of the
two images using out = a * x + b * ( 1 - x ), where x is the iteration (0 -
1), and a and b are the pixels from picture A and picture B... If both
pictures are the same size, it is easier.
You can optimize this, but the idea is the same. You don't have to use the
two for loops, and you don't even have to use the unflatten image, but it is
easier to get started.
When done, hide the picture control with a property node.
Wiebe.
Zguljo
Member
Thank you guys very much. I'll give it a try, particulary the idea with pic in other VI with tagged transparency for loop control.
Thanks one again, regards
Vedran
Yamaeda
Proven Zealot
As i'm thinking of adding a splash screen to our project i tried the ideas mentioned and found a bug.
Removing Title bar slow the transition by a factor 4!
With 20 ms loops i get a beutiful 2 sec transition on my modal application with 0% tranparacy (custom setting), but removing the Show Title bar makes it a ~8 sec transition, any ideas?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Wiebe@CARYA
Active Participant
I can't reproduce it in LV 8.5.1.
What version are you using?
Wiebe.
Yamaeda
Proven Zealot
I'm using LabVIEW 8.2
Qestit Systems
wiebe@CARYA
Knight of NI
Message contains an attachment
It works properly in 8.2.1 as well. Try running this in 8.2.
Wiebe.
Neil.Pate
Active Participant
Based on the advice from Wiebe I made my splash screen fade out using transparency.
Oddly enough, on a batch of PCs that are clones of each other (identical HW, with the OS imaged from a single source) it fades out at different speeds. Some run far slower than the others, and I have no idea why!
Yamaeda
Proven Zealot
I just tried the 8.2.1 you posted and it worked fine ... for 15 secs Smiley Happy
I noticed my splash is alot bigger, so i copied your picture 3 times and tried it again, and most of the behaviour is back.
Qestit Systems
