picture in header?
Is it possible to load a picture in my header using the print VI's? If not is there a work around?
thanks in advance
(3,795 Views)
Are you referring to the built-in Report VIs in the "Report Generation" palette? If so, I would think the "Image in Header or Footer" is the function you want, no?
(3,773 Views)
Yes that is correct, but how can I do that?
(3,771 Views)
Have you taken a look at the report examples that ship with LabVIEW? Select "Help->Example Finder..." and then enter "report" in the Search tab. The example "Sample Test Report" uses this function.
(3,768 Views)
hmm I looked at a other example. I'didn't have this VI in my own pallet but I'll copy it from the example. Thanks a lot.
(3,764 Views)
Hmmm... I never noticed that. I was looking at the example when I mentioned the name of the function in my initial response. That VI is in the Report library that comes with LabVIEW, but seems to be missing from the palette. They do have the "Append Image to Report" VI in the palette, though. Odd. Probably an oversight on NI's part.
(3,760 Views)
