picture without border
I'd like to display a picture control without a border. I want to make it look like a picture is just floating over the background.
TIA,
Bill F
(3,717 Views)
You can right click on the border using the paint palette and select T (on the right top corner of the paint selection palette). This will make your border transparent.
(3,710 Views)
You need to bring up your Tools palette and select the brush tool at the bottom. Now right click on the boarder of the picture control and in the color palette, select the small box in the upper right with the little 'T' in it. This is the transparent color.
The attached image shows the same picture with and without a boarder.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,708 Views)
