pid control coupled tank
Hye all......
i  want to develop graphical user interfaces PID Controller to control level height  and interfaces with coupled tank apparatus using NI-DAQ USB 6008......
i've found some good examples and i attached here.......i've already edit and there is 1 error to be solve.......
my problem is the simulation can't be run because there is some error
~SubVi 'IO Duncan .vi :SubVI is missing.......
can you help me on how to edit these problem???? as long as the simulation can be simulate..........
thanx 4ur help......
regards.....
azlan......
(3,332 Views)
Accepted by topic author azlan_mhs
It sounds like that when you downloaded/saved the example code you have been working on you didn't download the SubVi 'IO Duncan .vi  - so LabVIEW can not find it.
In the same way you have not included the PID subvi you are using so when I open your VI I get an error saying that it is missing.
David
www.controlsoftwaresolutions.com
(3,315 Views)
