pid duty cycle PWM
Accepted by topic author JohnS11
Even easier than In Range and Coerce, the PID function has an "Output Limits" input.  Create a constant for that input and set the limits to whatever you need.
What DAQ card are you using?  If it has a built-in timer, you will get a better PWM signal by using that, and the code is simpler.
Message 11 of 11
(594 Views)
