pie chart problem with label!
I found this example of pie chart, I tried to use several pie charts but the label square move in some chart. It shows the square moved down when it uses the vi.
I attached the example with 4 pie charts and sometimes it show the 4 sqaures and sometimes down one. Any way to fit it?.
I would like to see some example with 3d pie chart. Do you know any example?.
Thanks in advance!.
Fred
(3,644 Views)
Accepted by topic author Fonsi
Sorry guys!. i got it.
Changing the first time call to comparison of For Loop = 0, so always start with the value fixed to draw the square.
Thanks.
(3,604 Views)
