place checkmark in shortcut menu
Dear All,
Is there any way to place checkmark in shortcut menus?
Ritesh
Message 1 of 13
(4,806 Views)
Hello ritesh024... 🙂
Are you talking about checkbox dialog or something else...?
Message 2 of 13
(4,805 Views)
Hello Rupali,
I want to put a checkamark(tick mark) in front of the value selected in the short cut menu .
Ritesh
Message 3 of 13
(4,803 Views)
OK... Try this one...
Front panel - Controls - All Controls - Classic Controls - Classic Boolean - Dialog Checkbox
Hope it help you... 🙂
Message 4 of 13
(4,785 Views)
Accepted by topic author LVCoder
You need the 'Shortcut menu activation?' with the following code:
 Ton
Message Edited by TonP on 10-07-2008 10:22 AM
My LabVIEW Ideas
Message 5 of 13
(4,778 Views)
Hi Ton,
I have already set the item names in the menu. I am not adding them during the execution of the program.
However, when i tried placing a checkmark at one of the Tags, i got an error stating "LabVIEW : cannot find one or more tags".
Could you pls explain how can i  resolve this issue ?
thanks,
Ritesh
Message 6 of 13
(4,747 Views)
Could you upload your VI?
Ton
My LabVIEW Ideas
Message 7 of 13
(4,738 Views)
Hey Ton,
I just figured out that i was passing an empty string to the item Tag. Thats why i was getting that error.
Sorry for my carelessness.. :smileyindifferent:
Ritesh
Message 8 of 13
(4,734 Views)
So how do you determine which item was selected in the activation event frame?
Doug Ferguson
Message 9 of 13
(4,580 Views)
Hi Doug,
you can use the objectTag and objectPath string to determine the selected item.
Mike
Message 10 of 13
(4,578 Views)
