place pane origin
Hello
I use LABView 8.0. I would like to place the pane always on the same position. During development I'm using scroll bars and change the position of the pane. To place it back to the correct position, is there anywhere a solution. I tried to use the class pane.position for setting pane position. But there is the error message that this property is just readable. When I take a look in the help it should be also writable. I also read that there should be a class with origin. But I can't find it in this LABView 8.0 version.
(3,537 Views)
In LABView 7.1 the Pane.origin class is available. Where is it in 8.0?!
(3,533 Views)
the origin is in the pane class
(3,528 Views)
Here is also a thread about this topic.
http://forums.ni.com/ni/board/message?board.id=170&message.id=172227
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,522 Views)
