play music wma file by AO of carte usb 6251
Hey everyone,
Can i play music wma file throught analog output ni usb 6251. I have some error that my programe "Can not recognize the sound format". I am user of 8.5 Labview  version.
If someone knew and can help me, please.
Marek
Message 1 of 8
(3,605 Views)
Can you post your your sound file in zip format. Or is it to big?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 8
(3,601 Views)
Thanks Coq for your interest.
 This is exempel sound from "my music" Knew I have not other.
Message 3 of 8
(3,588 Views)
 This is exempel sound from "my music" .Now I have not other.
Message 4 of 8
(3,587 Views)
Accepted by topic author gfds
Your file wma type. Labview can only read wav files. But you can find a lot of free software that may convert your file to wav. It is somewhat big in wav format however 15 Mb
Message 5 of 8
(3,583 Views)
Thank you one more time Coq - this is nice
It work - I've taken some small part of all sound file and it is ok. When i've changed mp3 15Mb file that gave me about 70 Mb wav file- it charged a comupter hard.
Best regards
Marek
Message 6 of 8
(3,563 Views)
I do not hope you try to read the 70Mb in one piece and then play it. The trick is to read the big file in several small chunks. That will make your system more robust
Message 7 of 8
(3,553 Views)
Hi, may I know how do you output an audio signal using analog output? It using DAQ function right?
Message 8 of 8
(3,058 Views)
