play waveform on speakers on mac OS X
Hi all,
I am new to Labview, so this question might be much simpler than I thought it was, but it has been driving me crazy the past few days.
Basically, I work in a university research lab. For the purposes of one of our projects, I need to generate waveforms, and output them through the speakers of my computer.
I can do that fine on a PC running Windows XP, however the lab I work in mostly uses Macs under OS X. The problem is I can't figure out how to get the Mac to play the waveform I generate using Labview on its speakers (I use the same VI on Windows and Mac OS to generate the waveform).
Which leads to my questions:
1) What sort of "vi sequence" am I supposed to use to get a Mac under OS X to play a waveform on its speakers?
2) If I can't play a waveform on a Mac, what sort of output should I make my "waveform generator" have?
Please bare in mind I am relatively new to this, and might need a somewhat detailed answer.
Thank you,
- John
(2,977 Views)
John,
I have no trouble making my Mac make sounds. Dual G5, Mac OS X 10.4.11, LV 8.5 (but I have done it with many earlier versions as well).
I generate a sine array with the frequency and duration I want. I scale that to match the input to the Snd Write Waveform.vi. For the 16 bit inputs the scale is -32768 to + 32767. Set the sound format input to sound quality = mono, rate = 44100, bits per sample = 16 bit. Run.
Lynn
(2,972 Views)
