please help me regarding check box..plzzzzz
Did you look at my VI attached above?
Run it and click the checkbox. See what happens. Then look at the code to see how it's done.
(I assume you are talking about numeric indicators, not "textboxes", and you are talking about visibility, not values.)
Message 11 of 15
(729 Views)
here I have saved the subVis for LV 9.0 version....see if this works
You can use Visible property to disable or enable to controls within the states. Attached file also shows how to create a property node.
To understand the functionality run in highlight execution mode. Also if serial read and write VI gives error you can place a Diagram disable structure around it for now.
CLD
Message 12 of 15
(722 Views)
can you explaine me what is going on with the given VI. what is NEWVAL there in event structure. can you explaineme clearly. I am new to labview and i want learn things quickly..
Message 13 of 15
(687 Views)
Which LV distribution do you have? Is it the base one? The base one does not have event structures.
As a side note I think that events should be supported in ALL distributions. I can understand when they were this new thing that only advanced users would need. But they are becoming too mainstream now. It is almost like not having access to clusters unless you buy the professional version.
LabVIEW 2012
Message 14 of 15
(674 Views)
Message 15 of 15
(619 Views)
