please help me with this vi
hello friends i m new learner
plz help me
i have this program please tell me how to send readings and data in table in this vi and wwhen i press button log file it should log the file one by one ?? and
please tell me the logic too when i press next it should go to next page and back then back to page and on pressing exit it should exit and at last page next button should disappear .....
anyone plz help me
thanks in advance
        regards
        harmeet
Message 1 of 11
(3,643 Views)
here is vi
Message 2 of 11
(3,641 Views)
Are you expecting us to create an application for you? You would be better off if you show us what you have tried and we can then help you along the way. Please post an example of what you have attempted.
Also, please visit How to Learn NI LabVIEW and go through the self paced training on the right.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 3 of 11
(3,640 Views)
Now that you have posted the VI, you should notice that you have True constant connected to the stop condition of your while loop. That just means your VI will execute just once. Also, this leads me to believe that you need some training before you can program an application. Please go through what I have linked above and the LabVIEW examples before you attempt to program in LabVIEW. It will help you be a faster and better programmer.
Adnan Zafar
Message 4 of 11
(3,638 Views)
i know that vi is not completed i just created this vi within an hour
there are so many mistakes and faults
m just asking about my query
i know i m noob and very new to this
but sure i will learn it soon ...
if u can tell me the solution then its ok if not then also its ok ....
Message 5 of 11
(3,634 Views)
i am just asking i have values in control and indicators
how to send that values in table by pressing a button ???
Message 6 of 11
(3,631 Views)
now i have done this
few mistakes r coming can someone help me ???
calculation is not coming in table dnt know why ??
Message 7 of 11
(3,573 Views)
Accepted by topic author Harmeet Singh
Please use full words when typing messages on the forum and not "text message speak".  A plea for full words
One problem I see is that you have a lot of tunnels in your case structure where you did not wire the data in every case.  With the tunnels set for "Use default if unwired", you wind up feeding default data into your shift register which gets used later.  Probably not what you want.
Message 8 of 11
(3,567 Views)
Ok Sir i will keep that in my mind .. will write full
Thank you  Sir
its really helpful for me.
please tell me one more thing how to make "next button" disappear  in last page ?
Thank You In Advance.
Message 9 of 11
(3,560 Views)
(Oh, and the word "I" is always capitalized.)  Smiley Wink
You can write a False boolean to a property node of that button called "Visible".  Of course you will have to write a True to that property when you want it shown again.
But I don't like the idea of hiding buttons so much.  I think you'd be better off using the the "Disabled?" property and wire the constant "Disabled and Greyed" to it.  Then you can still see it, it is distinctively disabled, and functionally disabled.  You'd wire the constant set to "Enabled" to turn it back to normal.
Message 10 of 11
(3,555 Views)
