please help me
I am using an xy graph in my application.
Using the same graph iam displaying 2 choices.
One of the choices takes values from 0 to one only.
And the second one can take any range of value.
But when iam displaying the second one show scale from 0-1 and the values spread beyond the visible area(i have to scroll to see the result)
I couldnt fix the bug.Can anybody help me?
I posted one more question of printing graph in different orientation as mine one prints in only one orientation even if i have given more options and set vi's orientation to different mode during run time
(3,270 Views)
i've made a simple example just to see if something like you've said happened... But nothing. Can't you post a simple example of the problem that you got?
Tell me what's Labview version.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,263 Views)
Maybe set the scales to autoscale?
(3,226 Views)
Thank you for you reply
Yes i have set the scale to autoscale.
I have two buttons in front pannel to print two different parameters.
The first one takes values from 0-20 and the second one from 0-200.
But if i am clicking buttons one and two in interleaved manner,some times,the second one showing range from 0-20
and the values beyond 20 can be seen if we scroll the graph up(ie,above the visible portion)
I dont know whether you got my problem clearly.
But if you can,pleae reply me.
(3,202 Views)
Hello again,
If you post your problem.vi we can help you an much faster way.
Software developer
PORTUGAL
(3,195 Views)
No. Such a problem cannot be solved by a description. It seems you have a race condition.
Pleast attach your VI and make sure to include some typical data so we can run it. Also let us know how you operate it, e.g. what buttons you are pressing and in what order.
(3,172 Views)
