please help to solve the data type problem
Hello, In short I am building a application to control the NI5154 high speed digitizer. I want to build a master/slave loop to perform the acquisition and
data saving. I need to pass the fetched data array to the slave loop. The data to pass is a cluster which contains a array of "wfm info" cluster and a array
 of "wfmform" cluster. I dont't know how to define a data type which I can wire to the "open/create/replace datalog" function and the "Obtain Queue"
 function.
 I attached the vi and please see the broken lines.
 thanks a lot.
(3,103 Views)
That's simple. Right click on the output of the bundle function and select 'Create Constant'.
(3,101 Views)
thank you. wow a empty constant do remove the broken lines!
(3,092 Views)
Well when you read a datalog file you still need to tell the data type for the function to read data.
(3,081 Views)
