please help
i want to display the date, time and path in a table control of a pdf file created.
(3,642 Views)
Hi akshay,
and what is your problem? Where are you stuck?
Do you have problems with
- creating a table indicator?
- getting the desired values (date, time, path)?
- formatting those data to be able to show them in the table?
What is a "table control of a pdf file"?
(3,630 Views)
hello there
I have a pdf file and i want to fetch the information of that file ( location of the file , date and time of the creation of the file) and indicate the information in a table control
(3,625 Views)
Look into the File I/O palette.
Also, use a more descriptive subject title than "please help".  Pretty much everyone here is asking for help when they post a question.
(3,609 Views)
as a starting point, look for the functions in help and on the functions-palette
this code above has several shortcomings ..
regards
EDIT: also i'd recommend skimming through this post https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,608 Views)
