plot array
Hi everyone!!
I have an array that it has [0000111100001111]. I would like plot two graphs from this array. The first one it should be [00000000] and the second with [11111111]. I mean, in the array each element is repetated 4 times so this is the problem. I need something VI which I can select a bucle or something like that to build a new array each 4 times. Any idea???
Thank you!
(3,168 Views)
Hi kantabra,
      Not sure if this will solve your problem. This vi repeats each of the element of your input array(as configured by # of repetition per element).
(3,151 Views)
I don't understand your question. How did you get from [0000111100001111] to  [00000000] and  [11111111] ? Are you taking 4 elements at a time and alternating between 2 arrays? If the source array were [0001 0010 0011 0100] would the two arrays then be  [0001 0011] and  [0010 0100] ? Would they be something else?
(3,139 Views)
