plot ber vs eb/no for rician and rayleigh
hi
 i am trying to generate a plot against ber vs EB/no for rician and rayleigh channel but there is no option to increase eb/no in both the vi's like in the cae of AWGN vi  it has the option for increasing eb/no ?? what should i do ??
thnx
Regards
(3,286 Views)
Hi nolsqn,
Can you be more specific about which VIs you are referring to and what hardware are you working with? Are you using an example to generate your data? You may be able to change some of the parameters that affect the Eb/N0 to achieve the effect you are looking for. Is it possible for you to increase the carrier power, bandwidth, or decrease the data rate?
Steve B
(3,254 Views)
