plot data from Bluetooth device
Hello'
I am a senior student working on a design project consisting of sending a biopotential picked up via an analog system asending it wirekessly using bluetooth to a pc. On the PC I need to plot the waveform of the data real time. I want to use labview as it has Bluetooth VIs embedded in it. I have benn able to communicate with my device but I don't know how to read the data in decimal and generate a waveform of the data. Any help will be appreciated.
I am  also considering using a virtual serial communication between the PC and the device. but I have the same problem here too.
knot
mrkhou@yahoo.fr
(2,977 Views)
Hi mrkhou,
see the attached example. I hope it helps.
Mike
(2,968 Views)
