plot graph using array
Hi vernyew,
I tried that function before is different from what you had. I d/l the trial version of LV8.6 and found out that there is the option to Export Image but not in LV7.1. I think i need to think of another way to do that.
Message 11 of 14
(2,239 Views)
In 7.1, there is the Get Image method. If you look at the block diagram of the Append Control Image to Report, you will see it used and also how the data is passed to the Write JPG File function.
Message 12 of 14
(2,236 Views)
Thank you for the information, if i want to put the image of my file to MS word, how should i do that?
Message 13 of 14
(2,227 Views)
 With the NI Office Report Generation Toolkit you can export images to MS office files (word for instance).
Ton
My LabVIEW Ideas
Message 14 of 14
(2,217 Views)
