plot multiple graphs from excel table
I want to plot multiple graph which collect data from excel file where X axis is fixed in the range of 1 to 50. I want to compare different 50 data of Y axis. what can I do for this?
Message 1 of 8
(4,650 Views)
Hi yash,
Well, you need to:
- read the Excel data (is this really an Excel file - or just simple CSV data?)
- plot the data on graph(s)
- do the comparison as required
What have you tried so far? Where are you stuck?
Do you want multiple graphs - or just multiple plots in just one graph?
Different to what?
Message 2 of 8
(4,647 Views)
It is usually most helpful to us (in order to help you) if you include (a) the code that you have tried (or started) to write to solve your problem, and (b) an example of the data that you want to read/analyze/write.  Doing so would have answered several of GerdW's questions ...
Bob Schor
Message 3 of 8
(4,607 Views)
The type of posts that appear when LabVIEW jobs are exported to India!
Message 4 of 8
(4,596 Views)
hello everyone,
sorry for late reply.
I have attached my data file. so you can understand what I want to plot. I have used text delimited file to read data. but after reading these data, I have no idea to create multiple plot in just one graph.
Message 5 of 8
(4,572 Views)
Hi yash,
so you have a text file and we should create a VI for you?
And why don't you try to learn from other people in this forum with basically the same problem at the same time?
Message 6 of 8
(4,565 Views)
hi,
No I didn't mean that you create a VI for me. I have used ' Read delimited spreadsheet.vi' to read data from this file,but I have no idea for next step.I need help for plotting these data in one graph.
Message 7 of 8
(4,562 Views)
Hi yash,
again: what have you tried so far? How does your VI look like?
Which datatype did you use when reading the spreadsheet file?
Simple steps:
Index the columns, then build plots from them.
Put those plots into an array of plot and wire this array to your graph.
Message 8 of 8
(4,559 Views)
