plot numeric waveform with absolute time
Hi all,
This code was working with Labview 2009, but it doesn't seems to work with 2010, do I make something wrong ?
V-F
Message 1 of 13
(4,859 Views)
Hi ramses64,
you're right.
Your example isn't working with LV2010 SP1.
I tried so solve your problem with a workaround.
Please check it, if this is ok for you.
Best regards
Dippi
Message 2 of 13
(4,840 Views)
thanks for your answer.
This solution doesn't solve my problem : I want to display digital signals (same problem on mixed graph) on absolute time, not relative.
And my signal hasn't constant dt, so I used this method in LV 2009, and that was working...
V-F
Message 3 of 13
(4,834 Views)
Hi ramses64,
I installed LV 2009 SP1 and tested your example.
And it doesn't work...
What can we do now?
regards
Dippi
Message 4 of 13
(4,821 Views)
on my previous (dead) computer, I had 2009 F3 (download here : http://joule.ni.com/nidu/cds/view/p/id/1542/lang/fr )
Could you please test with this patch Smiley Wink (I'm really sure that this method worked before !)
V-F
Message 5 of 13
(4,818 Views)
Hi ramses64,
I set up a complete new system.
Then I first installed LabVIEW 2009 (without any Patch)
==> See Screenshot "LV2009_Test.jpg"
Afterwards I installed F3 patch
==> See Screenshot "PatchF3 Update.jpg"
At least I tested your example with LabVIEW 2009 F3
==> See Screenshot "LV2009F3_Test.jpg"
Somehow it doesn't work.
Because of that, I can't go to R&D and show them that behaviour.
Regards
Dippi
Message 6 of 13
(4,792 Views)
thanks for your reply,
I will install LV2009 with F3 patch, and will prove to you that I'm not dreaming (I hope !) Smiley Wink
I'll come back soon.
V-F
Message 7 of 13
(4,777 Views)
I have no time to test with a blank OS, and LV 2009 with F3, but I think (and I'm sure) this is a bug.
My problem : I want to plot a numerical XY graph, with absolute time : instead of writing a huge quantities of datas, I want to write only when a change occurs, to avoid useless datas, and overcharging CPU !
Is there a way to do this ?
V-F
Message 8 of 13
(4,762 Views)
Hi ramses64,
see attached example.
I delete the FIRST timestamp.
Because of that your time starts now at zero...
Like this it works...
Please take a look at it...
Dippi
Message 9 of 13
(4,749 Views)
what you've done is ploting the datas in relative time.
What I want is to plot it in absolute time...
Relative time : starts at 0, no date, no reference
Absolute time : start at a date, date included
Sorry, it's not what i'm trying to do.
The problem I think is that the X value of waveform has for max 4294967295, which is 32 bits. When you convert a timestamp to dbl, you need a 64 bits format.
So the problem is there !
V-F
Message 10 of 13
(4,742 Views)
