07-23-2018 09:52 AM
hello,
I am making a program with Keithley 2420. It's not showing any error but it's not giving any plot and the plot division is not correct. can somebody please help me out of this?
Solved! Go to Solution.
07-23-2018 11:27 AM
2 things:
1. Have you checked to make sure the correct values are coming in through all of the wires by probing them or putting indicators on them?
2. The "Build XY graph" express VI clears its data each time it's called unless you wire a False constant into the "Reset" input.
