plot the waveform
hi everybody,
I have these set of data (please see the attched pic). each row correspond the harmonic. for eaxmple the first one is the faundamental, the second one is the second harmonic and so on untill the sixth harmonic. I got these data from the receiver and they are in power (dbm). I am trying to plot the waveform of this signal but I am not sure how to do that.
could any of you please help me to plot it. I will be really appreciate you help.
Thank you
best regards
Thoalfukar
(3,862 Views)
Thoalfukar,
You can wire an array of complex numbers directly to the XY graph.
Lynn
(3,849 Views)
But I beed to plot the resultant of all these components
(3,835 Views)
The use Complex to Polar and wire the magnitude (r) output to a waveform graph.  Complex to Polar is in the Numeric >> Complex palette.
Lynn
(3,832 Views)
Dear Lynn,
thank you for your attention.
the data in the table sould b considered as frequency domain. and in this case I need to plot the waveform of the frequency domain data.
I wish you have a way to help me to plot the data in that case.
Thank you
best regards
Thoalfukar
(3,807 Views)
