plot to different layers in Origin
Hi everyone,
I'm trying to figure out how to plot data I collect in Labview to graphs in Origin.  My real program collects 5 columns of data and sends it to a new workbook in Origin.  My problem is with plotting columns to separate layers.  I attached a simplified VI of the plotting portion of my code.  I want to plot column B to layer one in the graph and plot column C to layer two in the graph.  If I just use a single property node for the layer, I can plot either column to either layer.  However, when I use the second property node it appears to put re-assign column B to layer 2 along with column C.  Does anyone have experience with controlling Origin from Labview?  Origin's documentation is pretty minimal.  Thanks!
(3,937 Views)
Hi Drummerguy,
I was doing some research, and it appears that Origins in a third party software. For more information and support on this, I suggest contacting that company. National Instrument's doesn't directly support this software. Sorry and have a good day.
Michelle G
Applications Engineering
(3,904 Views)
