plot vertical line on top of intensity graph at certain x value
Message 1 of 10
(4,436 Views)
I am not positive this is what you are looking for, but you could enable a cursor on the intesity graph and set the x position of the cursor. This could be assigned statically or dynamically using property nodes.
Message 2 of 10
(4,428 Views)
If I were to use cursors, do you know how I could create multiple ones without using the front panel. Basically I want to be able to click on my intensity graph with the mouse and have a cursor appear at that location. However I do not want there to be a limit on the number of cursors that can be created by clicking the mouse.
Message 3 of 10
(4,433 Views)
The main difficulty is to calculate the X position from the click position. First, you have to find the position in the graph pane. The left position of the pane is obtained by subtracting the width of the Y scale to its left position. Then there are some basic calculations to convert the click relative position to the corresponding X value, using the scale min and max.
The second point is to create a cursor. Use the "Cursor list" attribute, which is an array of all the available cursors properties, and append a new one to the list.
Attached is a simplified version of a tool I developed some times ago with the same goal.
It answers to questions you didn't ask :
- How can I move an existing cursor without creating a new one each time I click on the graph ?
answer : the cursors are only created when you hold down the key while clicking
- How can I remove a cursor ?
answer : hold the key down while clicking close to the cursor you want to delete.
Have a look at the way the closest cursor is detected, by calculating the distance between the click position and the cursors.
Since I still have difficulties with the size of the attached documents, the vi is divided in several subs.
CC
Chilly Charly    (aka CC)
Message 4 of 10
(4,394 Views)
Subs 1 and 2 (one more to come...)
Message 5 of 10
(4,393 Views)
Sub 1...
Message 6 of 10
(4,388 Views)
Sub 2
Message 7 of 10
(4,388 Views)
And sub 3...
Message 8 of 10
(4,388 Views)
is there any example?
Message 9 of 10
(4,152 Views)
You just replied in a thread that is over one year old and already contains several examples. What exactly are you looking for?
Message 10 of 10
(4,145 Views)
