plot voltage and current waveforms
Hello Every Body,
I am working on developing an RF measurement system. and this measurement system included RFSA and RFSG. I have four  RFSA's , each one receive powers A's and B's from the Generators. I need to plot the waveformes of the voltage and current received from these RFSA. Ok I know how to convert the A's and B's  to voltage and current but I don't know how to plot the these Data to generate the waveforms. I wish if there is any one could help me with this matter, I will be very appreciated.
Thank you soo much
best Regards
Thoalfukar Husseini
(4,368 Views)
What do you want your plots to look like?  What is the X-axis?  Do you want seperate graphs for the voltages and currents?
(4,350 Views)
Thanks for your Kind reply .
I want to plot the current and voltage in one plot. the x-axis should be time.
(4,339 Views)
Assuming you have two arrays for your voltage and current, just use Build Array to make a 2D array and wire that up to your graph.
(4,319 Views)
