ploting new plot in xy graph on button click
hi all experts
i need your help.
i want to plot multiple graph, on a single xy graph
i want -->if user want to plot a new plot
user will place new button,give value of parameter using control,do needed operation .
then press button name as plot.
on button click user must see all previous and new plot.
(3,292 Views)
You need use the build array function to append the new plot to the previous plots. "Help -> Find examples" has some good examples.
-Joe
(3,292 Views)
Joe is right, you will need to use build array to add plots to the previous one. Specifically, you can refer to the XY Graph.vi which demonstrates a couple different methods for graphing multiple plots to an XY Graph.
Jyoti F.
(3,292 Views)
thanks for your ans.
(3,292 Views)
