plotting a 4D graph from a 3D array
Thanks I will try to give this a go!
Message 11 of 13
(1,173 Views)
It worked out nice with the parametric plot as shown in the attached file. I just need to add some interpolation between the images in the stack, if you know of a method please let me know.
Message 12 of 13
(1,169 Views)
Thresold all of the values that are near the black end of your W-array and replace those values values with NaN.
Those values MAY not plot.
Or try to find a method that will let you set a transparency level. That may make it possible for the eye to connect the dots between the planes.
Ben
Message 13 of 13
(1,163 Views)
