plotting a data from LVM file
hello,
i am a student learning how to use labview in my project, my project is based on receiving analog data from arduino then plot it and save it for plotting it again sometime, i used "write to measurement file" vi to save the data as a lvm.file but when i try to plot it again in waveforme chart using " read from measurement file" nothing appears although i chose the correct lvm.file
i would like some help in this problem because im just beginner in labview and i don't have any other ideas .
Thanks in advance
othman nchifa
(3,358 Views)
Please don't attach pictures of your code -- attach the actual VIs.  We can't try out your code from pictures.  There are also pieces of information in the VI that isn't visible in the pictures.
Bob Schor
(3,325 Views)
sorry im new here
i tried that, but i realised that i can only drop a file with 33 mb max , so what should i do ?
(3,306 Views)
A 33MB VI is not normal! Reduce it to a small example.
Why is the VI so big? Tons of default data in controls/indicators? Gigantic diagram?
(3,302 Views)
ok,
done
(3,279 Views)
