plotting a graph at some time interval
Hello every one,
I  am trying to plot  a graph for  different power levels at different time interval.   I have tried  as attached VI with. But, it doesn't shown up(I couldn't  dispaly power vs time graph). would you go through and tell me what went wrong?
Thak you a lot
(3,450 Views)
Check your Build XY Graph properties.
You have it set to clear data on each call.
The number of steps control is unnecessary.  The For Loop will run a number of times based on however many elements you have in the arrays.
(3,434 Views)
