plotting close loop line in cartesian waveform that can be drag
Hi all,
I am a novice to labview.
How can i draw the lines in the cartesian waveform which is able to drag one of the joint around the cartesian space for different (x,y) - coordinate.
Thanks for ur help.
(2,718 Views)
I believe this VI performs the functionality you have described.  You have to first snap the cursor to the graph, select the data point you want to move, then unsnap the cursor from the graph and move the cursor wherever you want on the graph.  Then press change to update the changes.
(2,690 Views)
Thanks a lot man.
This help me have a better understanding.
(2,673 Views)
