plotting data on XY graph
I want to plot 4 values of Enthalpies against two values of Pressure
How it should be done in labview 8.2.1 using XY graph
I have attached the screenshot of graph how it would look .
Thanks & Regards,
Snehal Upadhye
CLAD
(2,767 Views)
Hi shehal LV lover,
                             Have you tried anything so far?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,761 Views)
Here is the link
--Ranjeet
(2,759 Views)
Hello Ranjit,
I have tried plotting XY graph so many times. But not getting the graph as expected.
Have you gone through my attachment regarding how my graph should look like randomly.
As there are 4 values of enthalpy and 2 of pressure;  remaining two values of enthalpy correspond to zero whcih should not be happening ideally
Firstly curve for entahlpies should be obtained and then P1 and P2 lines should be intersecting that curve.
There are 2D arrays for both pressure and enthalpy .
Kindly paste the solutions or VIs after converting them to labview 8.2.1 as I don't have any higher version of labview.
Snehal Upadhye
CLAD
(2,752 Views)
