plotting two 3D surface plots error
I am ploting 2 3d surface plots separately. One plots ok, the 2nd is giving me an error - plot number is out of range. Both plots have the same plot number - (1). Both are plotting similar data. Why is is one failing?
(2,773 Views)
Greetings, John!
I would first check the obvious things, like are you running out of memory? 3D charts can use a huge amount of it. Perhaps you can plot a couple of smaller data sets on your charts and see if you get the same error. You might also try a wiregrid format, instead of color, since color uses up a lot more memory.
Just a couple of hints.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,773 Views)
