plugin deployment crio
I have a problem of deployment of the chassis of my CompactRIO. When I want to launch an acquisition of a single track, it gives me the error hex 0x80DF001E plugin this element was not found Verify that appropriate software is installed.
I think the target rt does not start because it lacks a feature but I do not know why.
attached the error message.
Thank you
(2,714 Views)
Hey,
When you get the error message, which item is causing the problem?
You might want to post a screenshot.
Christian
(2,703 Views)
