pmod wifi with sbrio 9651 FPGA
Hello
I want to use pmod wifi with sbrio 9651 FPGA target.
pmod wifi is using SPI Protocol.
Is there any examples about pmod wifi in Labview??
I don't know how to use SPI protocol with pmod wifi in labview even if I study about spi labview example.
Thank you.
(1,484 Views)
I have found a few documents that may be able to point you in the right direction.
1. This is a tutorial on using LabVIEW with Pmods.
Using Pmod SubVIs – Digilent Inc. Blog
2. This has further documentation on Pmods and FPGAs.
Digilent Documentation [Reference.Digilentinc]
3. Here are some forum threads that are on the same topic.
-LabVIEW FPGA SPI with NI 9651 dev board - Discussion Forums - National Instruments
-Integrating Digilent pmods with sbRIO-9651 - Discussion Forums - National Instruments
4.Solved: How to program a SoM sbRIO-9651 - Discussion Forums - National Instruments
The thread creator marked a number of answers as the solution so go through the thread for further details.
5.NI sbRIO-9651 System on Module Development Kit Quick Start Guide - National Instruments
In section 4, this guide refers to an example that can be found in LabVIEW.
6.NI sbRIO-9651 Carrier Board Design Guide - National Instruments
This manual gives further details on configuring the FPGA and gives guidelines for the PCB Carrier Board. There is also a section on Temperature Alert signals.
7. Use FPGA I/O peripherials on sbRIO-9651 - Discussion Forums - National Instruments
8.Creating Component-Level IP for the sbRIO-9651 - NI CompactRIO Device Drivers Help - National Instru...
 I would also recommend contacting Digilent, as they will have further knowledge on connecting to LabVIEW with their Pmods.
Contact Us - Digilent Forum
Hope all this information will be useful for You.
(1,410 Views)
