png file vision processing application that can read hand image data
Reference material or any guide about developing a vision processing application that can read hand image data from a file and extract specific information about the hand like the number of fingers shown by the hand and if it is a left or right hand. You can assume all hand images are in png files with a size of 350 x 350 pixels. (Without installing any special vision libraries from NI)
A program that allows the user to open a png image file of a hand, and then counts the number of fingers, more processing to determine which fingers are extended and determining weather it is left or right hand.
Tahir
(1,623 Views)
Is this a class project?
Your question sounds remarkably like this one.  https://forums.ni.com/t5/LabVIEW/Pattern-Matching-find-the-fingers-by-recognizing-the-hand/m-p/40931...
(1,582 Views)
So, use the normal vision libraries from NI...
Or, use special vision libraries that are not from NI...
(1,556 Views)
Dear Tahir Yasin,
If you get any clue or solution you have plz provide me. i need help
(1,242 Views)
