png to 2D picture "ugly" result
First of all, sorry about I cannot define my problem better, but I am really not familiar with graphics handling, and picture transforming, so I can only say the result is ugly 🙂
I have a simple example png file, created from a vector graphic svg file, using Inkscape. Size of the png is 300 x 200, dpi: 270.
My problem is that, I would like to present this png picture on my front panel in good quality, in a 2D picture indicator. When I do this, the result looks "ugly" or "pixellized". Is there a way to display such png file in LV with a better quality (I have LV 2015 Pro 32bit, but no IMAQ and other similar toolkits available)? If I have a look at this png file using for example Irfanview, even after some zoom in, the picture looks good and "smooth".
Right now I use this simple way to load the png into the 2D Picture indicator:
I have also attached the png file for reference.
Edit:
when I compare the LV and Irfanview results (left is LV):
(5,629 Views)
As a workaround I just decided to use a picture ring, since for this project I have a predefinied static list of png pictures. Looks very sharp and nice 🙂
Anyway, I am also still interested how to display a png in a 2D picture indicator with good resolution...
(5,591 Views)
Accepted by topic author Blokk
I take your png and fill white background.
There is result (bottom img):
(5,574 Views)
Please attach the VI, or snippet.
"fill white background" How? Programmatically?
(5,565 Views)
Ok, i got it!
It looks like LabVIEW cannot handle png files with transparent background good. I have changed the transparent background to white using an image editor, and I get good result after importing to 2D Picture indicator.
Thanks, lesson learned 🙂
(5,549 Views)
There is an interesting thread on this subject,
Ben64
(5,515 Views)
Thanks Ben, indeed interesting! I keep this in my mind if I need to deal with transparent images again.
(5,503 Views)
