pocket pc 2005 and PDA module 8
most of the Pocket PC that there are in the market are working with opperation system 2005 .
I didn't understand : Do PDA module 8 can work with 2005 or I must work with only 2003 ?
Eran
(3,135 Views)
I understand you may have found documentation confusion, since the release notes LabVIEW PDA 7.1 (http://www.ni.com/pdf/manuals/323527b.pdf) for that product were written in 2004.  In any event, I think the following document contains the answer you're looking for:
Does the LabVIEW PDA Module Support Windows Mobile 5.0?
As a final note, I believe you cannot download the VIs directly in the Mobile 5 case.  Instead, you'll have to use your PDA's general file transfer mechanism.
Thank you,
Best Regards,
JLS
Best,
JLS
Sixclear
(3,126 Views)
Hi , thanks for your answer. I just have another question: Is that limitation you mentioned could affect the debugging options of an application that will run on the pda , can I still control the block diagram from my PC?
(3,111 Views)
Unfortunately, the debugging features will not work.  Basically, the built in communication mechanism used by LabVIEW PDA has not been updated for compatibility with Mobile 5.
Great questions,
Best Regards,
JLS
Best,
JLS
Sixclear
(3,076 Views)
