point (0,0)
I am using labVIEW6.0 to collect data. One of the points must always be (0,0). Howvever due to some instrument problem, I do not get (0,0). Is there a way to fix one point as always(0,0)?
(3,316 Views)
Assuming it is an arry I would just check for it and insert if missing.  Seems like a logical fix.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,315 Views)
I am using a For Loop to collect data. How to make sure that the data collected always includes a point(0,0)?
(3,292 Views)
I believe that Matt's answer is wise: after the data collection is finished, search a 0,0 by code: if you don't find it, insert 0,0 into your data.
How to do it is strongly dependent on how the data are structured. Without knowing this, we can give you very little help
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,284 Views)
