point and comma decimal separated values
I'm having difficulties getting the right values when converting from string to decimal floating point...
I am recording my annotations (string values) in a BDF+ file format and sometimes the recording device is a Dutch one, writing decimal separated value wit a comma like this: 5,678    but sometimes they record in the US and then i get 5.678
Now i want to convert my string values to a decimal floating point (single) is there a way, that the converter accepts both values and allways converts them using the dutch annotation with a comma?
Thijs
(3,386 Views)
Accepted by topic author ThijsBoeree
Solved it!!
Maybe there's a better way?
Anyone?
(3,379 Views)
Maybe you can use this link.
http://digital.ni.com/public.nsf/allkb/4B259A9CF98AD4628625697E00548EA0?OpenDocument
Hossein
(3,356 Views)
It was an old solution for LV 6.0
(3,349 Views)
Sorry about that. I found some info and an example (LabVIEW 2011) which is attached in this feedback.
http://digital.ni.com/public.nsf/allkb/894CF5FE064971BF8625758400014993?OpenDocument
Hope this helps!
Hossein
(3,328 Views)
