point display
I would like to display the center point of the image. I use IMAQ Light Meter (Point) to display the center point. Since I am using it more than once in my program I am unable to display the point in my front panel. Is there any method to display more than one point at a same instant in the program?
(3,348 Views)
You should try using Overlays instead. I've attached an example using IMAQ Overlay Rectangle, you could also use IMAQ Overlay Points. Take a look at it and let me know if you have any quesitons.
--Michelle
(3,311 Views)
I am still unable to plot two points. I tried using different colours for the two points. I capture image from say camera 1. I first plot the center of that image being captured. Then tried using IMAQ overlay point to plot my second point and sent it again to camera 1 as I wanted both the points seen on the same image. But I found that the output image from camera1 is not plotting both my center and the IMAQ overlay point.  Could you please correct me if I am wrong.
(3,236 Views)
