point two cursors at two different values in graph
hi
how to program my requirement.
i.e. get the two x-axis values automatically from the graph.New Bitmap Image.JPG
please give an idea to this.
i attached my requirement as image
Hari
Message 1 of 10
(5,345 Views)
You can add 2 cursors by right clicking on properties of graph/chart. And right click on graph, select visible items, Cursor Legend.
If you want to read the x-axis cursor values programmatically use property node, Cursor position.
See attached.
Message 2 of 10
(5,330 Views)
First of all.. Your attachement is not visible..
Second.. as a general understanding.. You can create two cursors and read their corresponding positions programmatically..
Mirash
Coding is a combination of intelligent and creative work - someone
Message 3 of 10
(5,329 Views)
Hi Mirash,
I attached again, from the below graph i like to get the X-axis values of both cursors programmatically.
when ever the two spikes occured i want the time occurence between them.
 From the i can able to get X-axis value statically.
Thank you
Hari
Message 4 of 10
(5,322 Views)
Hari,
You can follow the same method as GITA mentioned in the above post.
The attached VI has the same implementation.
Mirash
Message 5 of 10
(5,312 Views)
Hi Mirash
I did the same, I got the values by manualy moving the cursors.
But i want it by automaticaly, when ever the signals acquired cursors should point it automaticaly
and get the values without moving the cursors manually.
Hari
Message 6 of 10
(5,302 Views)
Message 7 of 10
(5,251 Views)
thankyou so much..Your image of the implementation was so perfect!
Message 8 of 10
(5,063 Views)
I have the same desire to put two vertical cursors on a graph and then choose to expand the X axis between the two cursors.  Obviously, there would also need to be a 'reset' to go back to full X axis scale.  I want to do this programmatically.  I know the tools already do this..   Thanks in advance.
Ron Brook
Message 9 of 10
(3,116 Views)
You're hijacking an old thread...
Anyway, something like this:
Message 10 of 10
(3,109 Views)
