points on axis of a XY Graph: programatically changing not always working
I have a minor issue:
Users can view data in my app, and in the academic world its usually appreicated if you have divided your X and Y axis in 6-7  points max.
So I use the appropriate property nodes for start of range, increment, minimum and maximum value. I dont need a minor increment.
However, Labview is still going its own way showing about 20 points on the Y axis!! To make it worse, sometimes it works, sometimes not.
Now I figured there must be a specific order in which I should execute the property node or do something else to make it work better.
Im on LV2010 btw. Thanks
(2,298 Views)
Can you post your code for us to look at?
Tim
GHSP
(2,296 Views)
